Re: Avoca Coffee & Tyre kick 7th. MarchSounds good to me
![]() Re: Avoca Coffee & Tyre kick 7th. Marchim ok with either
Re: Avoca Coffee & Tyre kick 7th. MarchC'est Carrickmines pour moi...!!!
![]() Climbed Elbrus, Island Peak, Kilimanjaro, Elgon, Everest BC, Mulhacen, Elgon, Kayaked the Liffey to the Nile, swam the Liffey, the Lee & packed ten triathlons into a year... catch me blogging on: http://www.teenagates.com
Re: Avoca Coffee & Tyre kick 7th. MarchNot as good as Avoca (the cake that is)!!
Guys, any of you fancy a start off at Avoca earlier to convoy over, I know a couple of you would be going that way anyway? Say 10am? S "I am not only a pacifist but a militant pacifist. I am willing to fight for peace.
Nothing will end war unless the people themselves refuse to go to war" - Albert Einstein
![]() Re: Avoca Coffee & Tyre kick 7th. MarchSounds good - I may not have my '5 ready in time (have to replace the front shocks and steering rods), but here's hoping it makes its first showing of 2010
![]() Re: Avoca Coffee & Tyre kick 7th. MarchShena, the convoy from Avoca sounds good.
Stig, JohnL and anyone else coming from the south can join in en-route and arrive at Avoca for, possibly, a quick cuppa and then on to Carrickmines. Add pick-up points;
![]() Re: Avoca Coffee & Tyre kick 7th. MarchYip I am on for the convoy from Avoca agree with Shena cakes much nicer ! See you at 10am. How can I compete with the Naviwaxers................ I even have a mould problem inside the soft top. Hope the weather is good on Saturday to lash a bit of TLC on P. I have been surfng a few different posts did Ivan really buy that gorgeous MX5 plum coloured car if so can't wait to see it on the road. Teenag fair play to you for heading North in the snow! I wouldn't head to Tesco and it is 5 mins away.
See you all Sunday ![]()
![]() Re: Avoca Coffee & Tyre kick 7th. MarchSorry guys, have just been told I have to go to a confirmation on Sunday, so no tyre kick for me. It should be pointed out that it was the Avoca shop/restaurant at Rathcoole (on the N7) that was the original suggestion, just in case anyone thinks it's a different one
Pretty sure I'm working Sunday ![]() John
![]() Re: Avoca Coffee & Tyre kick 7th. MarchIs it squeaking ? Might be one of the pulleys, then. Powersteetrng, waterpump or aircon...
ahhh feck, you spoke too soon, remember you said you thought you had it sorted. ![]() ![]()
It's the belt for alternator, being eaten by something, I suspect the pulley as it appears to be quite corroded , and the smell of burning rubber (no sniggering in the cheap seats) through the vents is sickening.On 4th belt since this time last year. I won't be taking the car too far from home until the problem is resolved. @ Ollie.. Yeah, spoke too soon but will have to tackle it again, asap John
![]() Re: Avoca Coffee & Tyre kick 7th. MarchThe pulley is in 2 halves. They should be tight with no wobble when you spin it without a belt. Clean the rust off with course emery cloth. When fitting the belt, tighten it just enough that so that on its longest length between pulleys, you can just manage to twist it by hand, 90 degrees. Same goes for any other belts.
HTH. The perfection of a Car's beauty is that nothing should be there for beauty's sake.
![]() Re: Avoca Coffee & Tyre kick 7th. MarchMy alternator belt got badly chewed up at Christmas. I had the charging light come on so I tightened the belt. I think I tightened too much which caused the problem. I replaced the belt and went for a short run tonight and it seems ok. As pointed out, the tension of the belts is important.
