change radiator
change radiator
Postby slom75 » Sun, 16 Mar 2008 5:14 +0000
Had a liitle accident and need to replace radiator and would really like to do the job myself (if possible) but I m a bit of a novice. I have removed the nose and was wondering if the next move is to remove the rest of the front or do i work over this ???????????
slom75
Postby mx5ash » Sun, 16 Mar 2008 6:30 +0000
Haynes manual says
Drain coolant
Remove cooling fans
disconnect resivor tank pipe from filler neck, loosen the rad hose clamps the upper and lower hoses
if auto remove oil cooler hose. (doubt you are so not typing rest of this line)
remove the rad upper mounting bolts (one each side) and lower mounting pins. lift the rad out. Being careful not to damage fins.
NOTE the bottom of the rad is retained without bolts by the rad support frame.
Probably a little late but hope that helps some way.
Postby Steve » Mon, 17 Mar 2008 10:17 +0000
Yup, shouldn't take more than an hour, no need to remove the nose cone.
