Remove the aerial mast
Postby fez » Thu, 14 Mar 2013 1:54 +0000
Trying to install a stubby aerial kit from mx5 parts. anywhere I've googled for removing the aerial mast says that it unscrews from the base with 2 flat edges on the last parts. However mine is round all the way down. I'm very confused. Maybe I have an aftermarket unit. Does anyone know if the Eunos S Special came with manual or electric aerial?
fez
Re: Remove the aerial mast
Postby Steve » Thu, 14 Mar 2013 2:25 +0000
is there a screw on it on the inside of the body work or is there a finisher over the part with the flat edges?
Postby fez » Thu, 14 Mar 2013 2:59 +0000
on the outside it's held by a nut, with a metallic curved washer thing, then a rubber thing which slots into a slotted dome. On the underside it's got a thing with teeth that grip into the body when its tightened. I hope this makes sense.
fez
Postby Fergus » Fri, 15 Mar 2013 1:16 +0000
You probably have an after market part there.
Best to just 'look' on the outside for where a spanner can grip and 'look' underside near the battery where another spanner can grip.
Other than that the main aerial could just screw off by itself and then you'll be able to see how the 'mount' is connected to the car.
Hey, post up some pics and we'll tell you !!
Postby MX5Spares » Fri, 15 Mar 2013 8:15 +0000
Fergus 'if you call me or drop over I will sort it for u.We also have original stainless steel aerial,s and base and they are unbreakable .....
Postby fez » Fri, 15 Mar 2013 11:58 +0000
autocheck wrote:Fergus 'if you call me or drop over I will sort it for u.We also have original stainless steel aerial,s and base and they are unbreakable .....
feels like I've been out to you every weekend so far this year! :lol: How much for one of them bases?
fez
Postby MX5Spares » Fri, 15 Mar 2013 3:51 +0000
20e for complete unit base and mast (detachable mast)
