Elec windows not working
Postby Mazdadazda » Wed, 07 Aug 2019 10:16 +0000
I changed the centre console window switch,and fuses under dash, windows went up and down,and fuse blew, replaced....window worked again,then stopped....whats the issue :/
Mazdadazda
Re: Elec windows not working
Postby mrges » Thu, 08 Aug 2019 7:31 +0000
Just as a guess, it sounds like something is causing a short in the circuit. Might you have trapped a wire beneath the console? Or perhaps not fully connected a wire/connector which might be loose and hitting off somewhere/something it shouldn't be?
Postby Steve » Thu, 15 Aug 2019 1:26 +0000
this ^ if they worked before changing the console switch.
