Heating
Re: Heating
Postby sidewaysreilly » Tue, 05 Jan 2010 11:55 +0000
yeah or maybe ill just get the drysuit out of the van and connect the heater pipes to it Tom lad. :lol:
Re: Heating
Postby CashelMX5 » Tue, 05 Jan 2010 11:59 +0000
They say that poteen is a great man for heating up the body but don't tell spideóg :lol:
Re: Heating
Postby graham » Sat, 09 Jan 2010 1:14 +0000
I had a look under the dash today, the cold air is coming from where the red arrow is, should those two units be joined together? The seem to be the same size, I can't find anything loose that is causing the problem. It's almost as cold as when the air con is on!
Graham
graham
Re: Heating
Postby Steve » Sat, 09 Jan 2010 1:55 +0000
yes.. you are missing the clip between the blower and the aircon evaporator.
Give them a wipe to remove dust and gaffer tape them till you find one (any car being dismantled).
Re: Heating
Postby franksm » Sat, 09 Jan 2010 7:21 +0000
think you should still have had hot air going across that pipe despite the leak.
I am wondering if you have an air lock or blockage in the heater matrix under the dash there ? the two pipes from the engine go into either end of the matrix.
hope it's not your problem as to change the matrix means removing the whole dash !!
Re: Heating
Postby Steve » Sat, 09 Jan 2010 8:36 +0000
There would be some alright but you'd be suprised how much air you'd loose as its kinda pressurised up against the heater matrix.. (and the aircon evaporator in his case.. ), I know this as I ended up buying a mazda non-aircon pipe. After fitting it I realised my gaffer tape + coke bottle job was crap.
Re removing the dash, not so anymore apparently as somebody realised that if you cut the "in" copper pipe on the engine side of the firewall you can wiggle it out sideways from the passenger side of the dash. Then when replaced you can use a bit of hose and 2 clamps to connect up again. I'll post a link if I can find it.
Found it :
This is the side of the matrix, see one pipe has a rubber tube and the other doesn't ? You cut the one that doesn't. Then cut your new matrix in the same way with a plumbers pipe cutter and refit so that both use rubber tubes (why they didn't do this in the first place.. ?)
You can see 'em here :
Re: Heating
Postby satfan54 » Sat, 09 Jan 2010 10:24 +0000
Hello. Some information on the cooling system. May be common knowledge or might be of use. Mk1
Cheers.
Cooling system.part3.rar
Cooling system.part2.rar
Cooling system.part1.rar
satfan54
Re: Heating
Postby graham » Mon, 11 Jan 2010 2:42 +0000
Has anyone got a pic of what it should look like or a link to one ?
G
PS Steve, your pics didn't come through properly..
graham
Re: Heating
Postby Steve » Mon, 11 Jan 2010 11:35 +0000
Hey Graham,
I've attached them to this post. Can you see them now?
Cheers
Re: Heating
Postby graham » Mon, 18 Jan 2010 4:29 +0000
I'm a little lost, can someone remove their glove box and take a pic so I know exactly what it looks like?
It's not terribly urgent as I haven't had much chance to drive the 5 recently, we've had two new additions just before Christmas...
g
graham
Re: Heating
Postby Steve » Mon, 18 Jan 2010 4:53 +0000
Graham, I reckon for the mo' you should remove glovebox, apply duct/duck/gaffer tape, reassemble.
2 new additions?? Congrats indeed!!
Re: Heating
Postby graham » Mon, 18 Jan 2010 6:41 +0000
I'll just gaf it for now, but would rather fix it, when I have more time.
As for the new additions, a girl & a boy!
g
graham
Re: Heating
Postby Paschal » Mon, 18 Jan 2010 8:38 +0000
graham wrote:I'll just gaf it for now, but would rather fix it, when I have more time.
g
Graham, welcome to the twin club--mine are 16 now, so they do grow up! Any other twins on the site?? Paschal
Re: Heating
Postby graham » Tue, 19 Jan 2010 12:52 +0000
Thanks... I'm actually a twin myself!
g
graham
