Pad Change Problems
Pad Change Problems
Postby JPW » Sat, 14 Nov 2009 9:44 +0000
Having finally toasted my front pads at a track day yesterday, l decided to fit new pads and disks today. All seemed to be going OKish but l am struggling now. l think the piston is back as far as it will go (using a G-Clamp to push it in). But l can't get the caliper to drop down over the pads - it just won't accomodate them. Am l just being a wuss and not screwing hard enough (ooer)?
AKA Jeremy
Click below to check out my MX-5s in the Octane.ie garage:
Formerly 1.8 S-Special in Black
Now Cheap but Cheerful in Mariner Blue
JPW
Re: Pad Change Problems
Postby JPW » Sat, 14 Nov 2009 11:01 +0000
Always nice to be able to answer your own question. :mrgreen:
A bit of persistance did the trick. Will be doing it again in the morning when the red mist clears, then moving on to the remaining corners.
AKA Jeremy
JPW
Postby ger » Sun, 15 Nov 2009 9:35 +0000
don't forget to open the brake fluid reservoir under the bonnet, as you push the piston back the fluid level rises.
Postby Steve » Mon, 16 Nov 2009 3:28 +0000
and use the adjuster if retracting the pistons on the rear! ;-)
