Timing Light
Timing Light
Postby fabfiveferg » Fri, 20 Nov 2009 2:55 +0000
Anyone have a timimg light I could use in the Dublin area?
Got my car back with new timing belt etc on but he seems to have set the timing at standard and I've no power at the bottom end. Of course now I can't get hold of him
Re: Timing Light
Postby sidewaysreilly » Fri, 20 Nov 2009 3:16 +0000
Yeah i have 2, was bidding on 2 on e-bay and messed up one bid and ended up buying both so one is for sale.
Its a MAC Tools with inductive pickup, box and instructions with advance dial on it.
Cost me 80 euros. Well worth it.
Re: Timing Light
Postby fabfiveferg » Fri, 20 Nov 2009 3:56 +0000
Right.....ehm.....I only wanted to...look at it for 5 mins :wink:
Re: Timing Light
Postby sidewaysreilly » Fri, 20 Nov 2009 4:23 +0000
cheap skate lol.......in Swords now if ya wanna loan.......
Re: Timing Light
Postby fabfiveferg » Fri, 20 Nov 2009 6:43 +0000
Cheap skate? I'm most awfully offended. :lol:
Ger has kindly offere to call into me tomorrow so will sort it then.
Flippin car has cost me best part of €800 in te last 2 weeks. I can only afford my own Christmas present now
Re: Timing Light
Postby sidewaysreilly » Fri, 20 Nov 2009 7:33 +0000
i was sick when i ended up buying 2.......e-bay novice back then but it is a cracker for the money so if you know anyone who needs one??????
Re: Timing Light
Postby fabfiveferg » Sat, 21 Nov 2009 8:47 +0000
sidewaysreilly wrote: it is a cracker for the money
Is it an MP3 player as well? Are inferior timing lights afe minutes out?
Re: Timing Light
Postby eddie mellon » Tue, 24 Nov 2009 5:34 +0000
belt could be out a tooth Eddie
eddie mellon
Re: Timing Light
Postby fabfiveferg » Wed, 25 Nov 2009 10:41 +0000
Yeah thought of that. doesn't seem to be the case. it's running ok but not quite right now. Might be a problem with the cam angle sensor. Will confirm that when my cheapskate €20 Timing light arrives from ebay
Re: Timing Light
Postby Ivan » Wed, 25 Nov 2009 11:46 +0000
fabfiveferg wrote: I can only afford my own Christmas present now
What will you get? i have an idea for you......
Re: Timing Light
Postby fabfiveferg » Wed, 25 Nov 2009 12:06 +0000
[quote="Ivan
What will you get? i have an idea for you......[/quote]
Pray tell Ivan. It's bound to be good if it's your idea.
Re: Timing Light
Postby Ivan » Wed, 25 Nov 2009 2:34 +0000
fabfiveferg wrote:[quote="Ivan
Pray tell Ivan. It's bound to be good if it's your idea.[/quote]
Of Course it is, i only have good ideas and if they go wrong they are
someone else's idea.
I suggest you buy yourself a Timing light
Re: Timing Light
Postby fabfiveferg » Wed, 25 Nov 2009 2:45 +0000
Brilliant. I like that idea so much it almost feels like I had it myself
Re: Timing Light
Postby Ivan » Wed, 25 Nov 2009 2:50 +0000
fabfiveferg wrote:Brilliant. I like that idea so much it almost feels like I had it myself
Great Minds and all that..
Re: Timing Light
Postby sidewaysreilly » Wed, 25 Nov 2009 4:37 +0000
Good idea is right!!!!!
Watch if your light has timing advance features as the 5 employs a lost spark ignition system so your advance dial will read double the actual timing if if dial it back to zero degrees.
