Rust in the sills
Anyone else suffering rusty sills ? I see more and more MK1s afflicted this way - it seems to take effect in the panel at the end of the sill in front of each rear wheel.
Also at the bottom of the front wings - this part is easily fixed though, just needs unbolted at the bottom and crud removed from that trap behind it. Even with clearing the drain there with a screwdriver, you'll still find leaves, mud and crud.
My car is now starting to bubble on the lip of the rear arch, which is a surprise. There's a double flap of metal there where the inner wing is welded to the outer wing - the rust is barely visible on the paint outside, but is working its way between the twp bits of metal and is causing them to bulge. It almost looks like mechanical damage to the lip.
Anyway, the sills... I have had mine patched once already but see that more rust is forming in the same place - I bet it's because the sill is rull of crud plus maybe the welding material itself is prone to rust since it isn't coated ?
