1.8 clutch into 1.6
1.8 clutch into 1.6
Postby mx5ideways » Mon, 29 Mar 2010 8:22 +0000
hey guys,does anyone know the weight of the flywheel in the 1995 1.8 eunos roadster(heard they were lighter from the 1995 1.8 onwards somewhere) and is there any guides to taking it out? i ordered a spec 2 cerametalic 1.8 helix clutch from performance 5 last thurs for my 1.6 roadster but il need to take the flywheel out of my spare 1.8 to fit it,will i need to change anything else?
mx5ideways
Re: 1.8 clutch into 1.6
Postby Steve » Mon, 29 Mar 2010 9:02 +0000
Don't think you'll need to change anything else.
"This (1.8L) clutch was designed for 1.8L cars. A 1.8L flywheel is needed to fit a 1.8L clutch to a 1.6L car. A used 1.8L stock flywheel will bolt right up ..."
From here :
http://www.flyinmiata.com/index.php?deptid=4531&parentid=0&stocknumber=08-19000
Postby mx5ideways » Mon, 29 Mar 2010 9:40 +0000
ok thanks steve
mx5ideways
