Exhaust and door
Exhaust and door
Postby arnoldblackanddecker » Thu, 10 Jun 2010 1:49 +0000
Hi guys, quick one that someone may be able to answer. Seem to remember a post about someone who does bespoke exhausts/part exhausts, I think it was in trim/navan. I basically need from cat to just before the backbox.
Also, went to open the drivers door the other day and heard a 'springing' noise, door pull no longer works, but it's stuck locked. Is it possible to remove the door cards without opening the door? Just to make things more complicated I've got a carbing rollcage which comes down diagonally across the lower part of the door.
Thanks in advance!
Re: Exhaust and door
Postby Steve » Thu, 10 Jun 2010 5:27 +0000
Both inside + outside latches + key are useless I take it? Mine got stuck before and needed the key to be "flicked" to open and then it opened. There is a wee spring that pops off.
Not possible to remove the door card without damage tho' I'd think. Easiest way would be to cut a hole and flick the lock.
Heres where to cut :
Cheers,
Postby arnoldblackanddecker » Thu, 10 Jun 2010 5:42 +0000
Oh really? Ye, it's the door pull itself, whether I lock/unlock the door doesn't matter. I don't fancy the idea of cutting through the door card...should I be cutting into the outer hole, as it were, in that pic?
Postby Steve » Thu, 10 Jun 2010 8:55 +0000
yeah the leftmost, a new card shouldn't be too expensive.
Postby arnoldblackanddecker » Fri, 11 Jun 2010 11:56 +0000
Thanks steve
Postby arnoldblackanddecker » Mon, 14 Jun 2010 8:16 +0000
Ok, managed to peel the door card back a bit and separate it from the top part. Has anyone got a diagram of the door mechanism at all? I have rod's 1.8 shop manual but only shows how to remove door from hinges?
Postby Fergus » Thu, 15 Jul 2010 1:58 +0000
