PAS Rack Fitment
Hi Guys, hope all is well with you all.I recently replaced my PAS rack the other day as it was leaking terribly.Now I marked everything up but, now the steering lock is unequal on both sides when you turn too full lock.When you turn right I have one and half full rotation while left one and a a bit.I undo the pinch bolt on the universial joint rather than the one on the steering column.
The tracking is way off now as well as the left wheel is pointing out so will I redo the job or will tracking sort out the problem, I don't want too get bumpsteer.?
