ventilation system...
Postby jargarbo » Thu, 25 Nov 2010 3:04 +0000
Hi all it's been a while since I was here.
Something's just bugging me about my MX5. Every time I drive my car with heating on then get out of the car everything switched off... in few minutes time windows starts to mist from inside as in heavy mist in which it dont usually happen before. Not sure if the air filter is blocked or there's something wrong with electrical?
Tried searching about cleaning the vents for MX5 but didnt found any. Please help!
jargarbo
Postby MX5Steve » Thu, 25 Nov 2010 8:50 +0000
Lift your carpets by the footwell see if there wet. Sounds like theres water somewhere. Also check behind rear seats and parcel shelf, water will be hear if roof/rain rail is leaking.
Re: ventilation system...
Postby Steve » Thu, 25 Nov 2010 12:52 +0000
have a read of this topic too :
Drain holes
Postby cseaj » Thu, 25 Nov 2010 5:02 +0000
hi all is this not a common thing at this time of year mine is the same and same thing last year i lifted carpets cleaned drain plug but still the same so this year i got a couple of small bags of silica gel and there suppossed to absorbe miosture so going to try these out
cseaj
Postby jargarbo » Thu, 25 Nov 2010 8:43 +0000
Thanks very much guys! I know this is the best website to ask any probs about MX5's. Will try them out tomorrow and see if there's pool of water or leaks. I know there was before but sent it to the garage and fix a leak on the passenger side just beside the glove box compartment.
jargarbo
