Jump start dead battery and suitable replacement
Postby robmx5 » Sun, 28 Nov 2010 8:09 +0000
Folks,
Need to try and jumpm start my car but can't tell which is the positive and which is the negative - any ideas ?
Also battery has a third cable coming out of it and into the bodywork - I'm assuming this is some sort of earth - any ideas ? Is this required for a new battery ?
Finally, any recommendations for a new battery - priced one in Halfords with 5 year guarantee for €107 yoyos - anybody have one of these and knwo if they fit properly ?
Spideog
Re: Jump start dead battery and suitable replacement
Postby graham » Sun, 28 Nov 2010 10:49 +0000
The terminal that is closest to the body of the car is the negative, ie the one on the right hand side as you look into the boot.
Be careful what battery you buy, you need to get a sealed battery.
Get this one: http://www.mx5parts.co.uk/product_info. ... cts_id/635
g
graham
Postby robmx5 » Sun, 28 Nov 2010 10:54 +0000
Cheers Graham - I assume thats the terminal towards the back of the car and the positive is towards the front so.
Does if have to be a sealed one, or is a sealed one just better.
Spideog
Postby barney » Sun, 28 Nov 2010 10:55 +0000
the third ''cable'' wouldn't be the vent pipe from the battery that goes through the floor?
Postby graham » Sun, 28 Nov 2010 11:21 +0000
It has to be a sealed battery! Unless you want corrosion in the boot.
Your battery might be in a slightly different position as my one, but it should be be obvious, the battery should be labelled anyway, The negative terminal will probably be connected to the body, so it should be easy to spot. send in a photo and we'll be able to confirm which one it is.
g
graham
Postby mx5ash » Mon, 29 Nov 2010 10:51 +0000
Is the battery in the boot on mk2s?
Postby robmx5 » Mon, 29 Nov 2010 8:05 +0000
Yes, battery is in boot but is sitting lengthways, front to back - will try to get a photo up
Spideog
Postby robmx5 » Mon, 29 Nov 2010 8:20 +0000
Here it is lying front to back
spideog
Postby graham » Mon, 29 Nov 2010 11:11 +0000
I would assume it the one on the left with the plastic cover on it. I'm sure someone else will be able to confirm.
g
graham
Postby sidewaysreilly » Tue, 30 Nov 2010 2:03 +0000
get a multimeter off someone to verify voltage......there will be some albeit very little........then swap from one pole to a good earth . This will show the positive pole.or try a continuity check with a good earth in the boot. You will have continuity with the negative terminal to the body. Are the poles the same diameter??? The earth(minus) is always/usually smaller.
Postby Steve » Tue, 30 Nov 2010 2:57 +0000
there should be a + and a - on the plastic of the battery beside each terminal too.
Postby sspecdave » Tue, 30 Nov 2010 6:12 +0000
Rob
Checked my battery in the mk2 and the one with with gray plastic cover is indeed the positive . I changed sealed battery a while back and fitted a standard EXIDE EXCELL EB 442 (44AH 420A 12VOLT) bought in a local autofactors .
Hope this helps
Dave
Postby robmx5 » Tue, 30 Nov 2010 8:36 +0000
Fair play lads - again
Spideog
Postby Reesy » Sat, 11 Dec 2010 7:18 +0000
The gel battery on the '5 was dead so I jumped off wifey's golf. After half an hour of idling it was still hardly charged at all, so i reckon the battery's gone. it's only two and a half years old... and a 2 year warranty.
Anyone know a cheaper place to get a gel battery than MX5parts?
Reesy
Postby johnv » Sun, 12 Dec 2010 6:16 +0000
im going to talk to a guy tomorrow about a gel battery will let you know
johnv
