Bose Stereo Removal
Bose Stereo Removal
Postby pjmazda » Mon, 10 Jan 2011 10:22 +0000
Hi Guys,
Any clues how I get this Bose Stereo (see attached) out of my 98 Mk2 Eunos?
I pulled off the small side panels on unit and found 3 holes in each side.
I tried screwdrivers, nails, some U thing from Halfords, basically everything and I can't get it out. Any help would be much appreciated.
Thanks,
P.J.
pjmazda
Re: Bose Stereo Removal
Postby charged_rs » Mon, 10 Jan 2011 11:14 +0000
it will be bolted into the dash using the double din brackets
to get at the bolts you need to
unscrew gearknob
remove centre console,
remove radio surround( carefully or it can break)
remove radio
Postby pjmazda » Wed, 19 Jan 2011 3:40 +0000
Thanks charged_rs, I eventually got this boyo out but had to do the following:-
- unscrew gearknob
- remove centre console
- remove radio surround
- remove radio front (in order to get at spring clips on either side of radio)
- squeezed in spring clips one by one with screwdriver
- slide radio out
pjmazda
