Problem:
NB 98 eunos roadster air conditioning not working.
Light comes on just fine when you switch on air con and turn fan on full however compressor clutch does not engage and hence no cold air from vents.
Solution:
Go to halfords and buy recharge kit 69 euros and charge up air con system as per instructions on can.
Basically the reason the clutch was not engaging was since pressure switch detected low pressure and would not allow power to clutch coil. During recharge clutch kicked in
and and like magic cold air from vents....happy days....
