Alternator
Alternator
Postby graham » Wed, 21 Sep 2011 12:57 +0000
How do I check if my alternator is charging the battery.
Graham
graham
Re: Alternator
Postby leamyj » Wed, 21 Sep 2011 1:30 +0000
Put a multimeter across the battery terminals as the engine is running, you should get a reading of between 11.5 and 13.5 volts ( I think)
Somebody confirm these are the correct readings???
Re: Alternator
Postby graham » Wed, 21 Sep 2011 2:14 +0000
OK, so its not my alternator! I checked it at the weekend and there was 12V coming from the battery...
g
graham
Alternator
Postby landmarkjohn » Wed, 21 Sep 2011 4:04 +0000
I think put a meter across the battery with engine running and you should get approx 13.5 V ( not at home to check at moment, maybe someone else can)
landmarkjohn
Re: Alternator
Postby Steve » Wed, 21 Sep 2011 4:28 +0000
+1
Its 13.5-14.5v with engine running I think.
Re: Alternator
Postby leamyj » Wed, 21 Sep 2011 8:28 +0000
Steve wrote:+1
yep..they'd be the right figures :wink:
j
Re: Alternator
Postby sidewaysreilly » Thu, 22 Sep 2011 2:49 +0000
simples, check battery reading with engine stopped. Start engine and check readings while a beaker assistant checks voltage.Voltage will rise when engine is revved.
Re: Alternator
Postby graham » Thu, 22 Sep 2011 9:32 +0000
I checked it last night,it was 14.5V. I'm gonna charge it for a few days and see if that sorts the issue.
g
graham
Re: Alternator
Postby leamyj » Thu, 22 Sep 2011 1:21 +0000
Put it on a trickle charge for a few days........
Re: Alternator
Postby cseaj » Thu, 22 Sep 2011 3:03 +0000
possibile : battery with 1 or more dead cells unable to hold the charge
replace battrey
chris
cseaj
Re: Alternator
Postby graham » Wed, 12 Oct 2011 10:36 +0000
Anyone replaced an alternator? I have a new battery which is also losing charge.
g
graham
Re: Alternator
Postby leamyj » Wed, 12 Oct 2011 7:08 +0000
graham wrote:Anyone replaced an alternator? I have a new battery which is also losing charge.
g
Easy enough job, expect some skinned knuckles though. Where you based?
Re: Alternator
Postby graham » Tue, 25 Oct 2011 10:51 +0000
Sorted! Just a dodgy connection!
I have a spare battery, it's just gonna go completely dead and have to be be chucked out, anyone got anything they want to trade for it?
Only one thing wrong with it one of the nipples for the venting broke off but I made a new one for it....
g
graham
