Hi,
The soft top of my 1998 Mk 2 car has started to leak.
does anyone know where I can buy a new roof and contact details for fitting??
Lucy.
Soft Top ReplacementHi,
The soft top of my 1998 Mk 2 car has started to leak. does anyone know where I can buy a new roof and contact details for fitting?? Lucy.
soft tophi Lucy you can buy replacements and fit them your self I got mine replaced By Arthur in web cars in Bray it seems great have had no problems, see Link http://www.webcars.net/softtop.htm
x5trebor
LucyI'm in the same boat at the moment. The price depends a lot on what type pf roof you want to fit and if your prepared or know someone that can do it for you. There are a couple of lads on here who have fitted them for other people - approx 6 hour job.
I am looking for a navy mohair hood. www.mx5parts.co.uk currently have genuine Mazda hoods on special offer. Appox €750.00 delivered - then I have to fit it. Art on webcars is charging approx. €1300.00 fitted. Another site worth looking at is www.mazda-mx5-shop.com - there hood is approx. €520 delivered (not a mazda hood though) A vinyl hood (normal) would be cheaper than all of the above. I believe its a good idea to replace the tension cables at the same time. Genuine Mazda hoods are suppossed to be good for up to 10 years if looked after - which means mine is at the end of its life. Hope that helps. Robin
Hi,
There's a guy in Neath, Wales - Jack Smith Trimmers I think he's called. See here http://www.mx5ocforum.co.uk/viewtopic.php?t=41553 - seems to be good service. I think he will ship them too. Simon No more Mk1, now driving an '08 Mk3. Still fun!
Re: Soft Top Replacement
If your in Cork I can fit it for you, I've done a good load of em here for the Cork lads in the club already. There are LOADS of hoods available out there but be sure to get a good quality one, the cheaper the hood then the more issues you'll have with it in the long term. There's also SFT: http://www.jagspares.co.uk/mx5/company.asp I got my Mohiar hood from them and it was a perfect fit. As for fitting a hood in 6 hours, thats with taking short cuts and not using Evo glue/rivets etc for example. If you need rubber seals etc then I'd go get them at less than half the price second handf from www.sniffydog.co.uk
(PS) Don't forget to get new cables while your at it:
http://www.mx5parts.co.uk/product_info. ... cts_id/451
New roofHi Guys,
Thanks for the help, I'm going to start ordering later this week. Fergus, I do live in Cork, I'm buying the cables and seals this week also. Lucy.
Soft Top FittingHi Fergus,
I don't have anyone to fit it at the moment. Lucy.
Window sealsHi,
I've received my mohair hood and tension cables. I'm now ordering the seals - I presume I need to order 6 - two front, middle & rear. Am I correct??? Thanks, Lucy.
Window sealsHi,
Hi Lucy,how are you getting on with your new roof? Has everything arrived and is it ready to be put in?
Sean og
Roof Seals - Help!!!Hi Sean,
I have the roof but I'm waiting to order the seals. Do I need Front, Middle and Rear seals for each side? Lucy.
