hardtop loose
hardtop loose
Postby scallan » Fri, 25 Nov 2011 10:32 +0000
hi having a problem lately that my hardtop keeps coming loose at the back on the frankinstien bolts and when on a bumpy road it just bangs and bangs and is going to end up driving me mad :( so any help is appriciated
thanks james
scallan
Re: hardtop loose
Postby charged_rs » Fri, 25 Nov 2011 11:05 +0000
scallan wrote:hi having a problem lately that my hardtop keeps coming loose at the back on the frankinstien bolts and when on a bumpy road it just bangs and bangs and is going to end up driving me mad :( so any help is appriciated
thanks james
1. remove your hardtop
2. on the chrome latches at the rear there is a little screw at the side of each latch - remove this and the latch will slide open
3. refit hardtop
4. loosen but (dont remove )the 2 exposed bolts
5. push the little plate under the 2 bolts forward as far as it will go , so it fits tightly against the mushroom bolts
6. retighten bolts
7. close latch and insert screw
job done
Re: hardtop loose
Postby scallan » Fri, 25 Nov 2011 11:08 +0000
[quote="charged_rs
3. refit hardtop
6. retighten bolts
job done[/quote]
have done this probaly 10 times in the last week with no avail :roll:
scallan
Re: hardtop loose
Postby charged_rs » Fri, 25 Nov 2011 11:21 +0000
chances are the plastic keeper ( edge) on the plate under the 2 bolts are worn out.
you need the build up the keeper again
remove plate completely and wrap the leading edge bit ( should be thick white plastic) up in insulating tape , nice and thick.
if that doest fix it them there is something seriously wrong as this is the only way to adjust your hardtop onto the mushroom bolts. :roll:
Re: hardtop loose
Postby scallan » Fri, 25 Nov 2011 12:02 +0000
charged_rs wrote:chances are the plastic keeper ( edge) on the plate under the 2 bolts are worn out.
thanks for that charged will try it when i get home as the plastic keepers do seem a lil bit worn hopefully this will work before i go mad with the noise :bom:
scallan
