Alternator Belt
Alternator Belt
Postby graham » Sat, 14 Jan 2012 1:50 +0000
My alternator belt has been slipping again, I fit a new one about a 2 months ago. How much should I adjust the belt? I tightened it till it stopped screeching and let the engine run at high revs for a bit and it seems grand now.
I bought one of these http://www.ebay.com/itm/12V-24V-RED-DIG ... 5ae46e6cf2 to check the voltage, much easier than a multimeter across the batter.
g
graham
Re: Alternator Belt
Postby leamyj » Sat, 14 Jan 2012 3:08 +0000
That's for nothing! Just bought one , less than €4, delivered :cheers:
Re: Alternator Belt
Postby sidewaysreilly » Sat, 14 Jan 2012 6:39 +0000
On any belt, you should be just able to twist it 90 degrees between thumb and finger at the centre point between pulleys on the longest distance.
Re: Alternator Belt
Postby graham » Tue, 17 Jan 2012 12:05 +0000
Grand, will double check it! It seemed fine last night, was out for a quick spin!
g
graham
Re: Alternator Belt
Postby graham » Sun, 22 Jan 2012 10:46 +0000
Damn belt is still slipping, how loose does the 14mm bolt at the pivot point need to before I tighten the adjuster?
g
graham
Re: Alternator Belt
Postby johnv » Mon, 23 Jan 2012 8:42 +0000
i had trouble with belts no matter how many times i adjusted them the still squeeled i bought a set of mazda belts never had a problem since
johnv
