Radiator top up / Black sooth
Postby graham » Sat, 31 Mar 2012 11:20 +0000
I had to change my thermostat as the engine was running high, I notice the rad isn't full, what mixture of water / antifreeze should I use to top up?
Also there seems to some black soot around the engine bay, I haven't really been driving the car much.
g
graham
Re: Radiator top up / Black sooth
Postby charged_rs » Sat, 31 Mar 2012 11:31 +0000
graham wrote:I had to change my thermostat as the engine was running high, I notice the rad isn't full, what mixture of water / antifreeze should I use to top up?
g
you need to use a 50/50 mix of water and coolant - the capacity of the cooling system is 6ltrs give or take a little.
take rad cap off , and start engine and let it get upto temp- 10 - 15 mins at idle...then top up the system and refit cap , job done.
as for the soot..havent a clue
Postby graham » Sat, 31 Mar 2012 11:33 +0000
The soot is a total mystery unless it's from a dodgy alternator belt I had, I'll clean it off and see if it comes back...
g
graham
Postby leamyj » Sun, 01 Apr 2012 1:06 +0000
I'd say it's a belt being ground down, happened to me when the pulley on the alternator was pitted with corrosion and was forever eating the belt(s)...check the pulley and make sure the inner surface is smooth.
