Thermostat housing
PostPosted: Sun, 08 Apr 2012 8:41 +0000
by graham
I over tightened one of the nuts for the thermostat housing and sheared it off. Anybody know where I can get a replacement and how to get the bit that's stuck out? I was think of some WD40 and a pliers as there is a good chunk sticking out.
G
Re: Thermostat housing
PostPosted: Sun, 08 Apr 2012 10:35 +0000
vice grips should do it, bring it in with you to a local hardware for a replacement.
PostPosted: Mon, 09 Apr 2012 7:17 +0000
by shaneh
http://www.mx5parts.co.uk/thermostat-housing-p-774.html
i had to buy 1 aswell.
not cheap but its good quality
PostPosted: Mon, 09 Apr 2012 10:32 +0000
by sidewaysreilly
can it be drilled out???
PostPosted: Sun, 15 Apr 2012 12:35 +0000
by graham
It just wont budge, the stub is starting to get a bit wrecked with me trying to get it out. Any tried and tested suggestions?
g
PostPosted: Sun, 15 Apr 2012 6:48 +0000
by sidewaysreilly
yeah, drill it and use an easy-out. If you take the housing off ill do it for you.
PostPosted: Tue, 17 Apr 2012 1:25 +0000
by graham
If only it was that easy... You need to remove the timing belt to get at the housing, taking it off would be fine, putting it back on would be an issue!
g
PostPosted: Tue, 17 Apr 2012 7:03 +0000
by sidewaysreilly
whare abouts are you?
