loose drivers door mirror
Postby Merlot man » Wed, 02 May 2012 10:32 +0000
Hello all ,I have a very loose driver's door mirror ,wont stay in its adjusted position. Passenger one is good and tight. Can it be tightened up or does it need to be replaced? Any and all help appreciated.
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
Re: loose drivers door mirror
Postby Steve » Thu, 03 May 2012 1:33 +0000
If you take it off, I think there is a central bolt that you can tighten up on the bottom side of some of the mirrors (mine at least).
Postby leamyj » Thu, 03 May 2012 7:07 +0000
You can also get replacement bolt/spring from mx5parts if it's badly corroded.
Postby Merlot man » Thu, 03 May 2012 7:41 +0000
Thanks for that lads, will take it off this evening.
Brian
93 na s ltd
Merlot man
