Just fitted softtop, can't latch it on[Solved]So, as the topic tells, it's fitted Robbins softtop, all well until last thing on the list, latch the new top an leave it for 2 weeks. It is missing 1-2 inches to latch on. Is it all just force required, or is there better ways of doing it?
x-'91 1.6
x-'94 1.8
Re: Just fitted softtop, can't latch it ondid you loosen the latch all the way out? If you look at the bit of the latch that grabs onto the windscreen header you'll see a plastic cover which flips out.
Then unwind the piece inside this (see pic) to loosen the latch. ![]()
Just fitted softtop, can't latch it onThanks for the tip. Already loosened as far as it could go.
x-'91 1.6
x-'94 1.8
Re: Just fitted softtop, can't latch it onSeems to be common problem 'this is why most people rather buy used roof intact with frame.You might need to loosen the 6 x 12mm bolts ( 3 on each pillar) and do not retighten till roof locks are closed .This might give you a bit of extrs movement on the frame which might help.
Re: Just fitted softtop, can't latch it onTurned out all that was needed was more manpower. Local gaming(card- and wargaming) night in UCC was my rescue, only took me and 6 other guys. Surely it could have been ok with less, but me and 3 others was not enough. Possibly because they are not car guys
x-'91 1.6
x-'94 1.8
Re: Just fitted softtop, can't latch it on[Solved]What I have found over the years fitting soft tops is to leave the 6 ( 3 each side) side pillar bolts loose until the roof locks to the header clamps over the windscreen and then tighten the 6 bolts.It gives the whole frame a little more slack.It might not be a bad idea to do this now as it seems your soft top is extra short ??It might tear ??
Re: Just fitted softtop, can't latch it on[Solved]Just your luck that Sunday will be fine and you won't be able to put the top down!
Just fitted softtop, can't latch it on[Solved]Autocheck: It isn't short, just a tight fit. As it is vinyl it will ease up over time. The 6 bolts did not give any forward play on my car.
I will probably try to open the top on Sunday on the run, if it is still hard I will have the help needed to latch on again x-'91 1.6
x-'94 1.8
Re: Just fitted softtop, can't latch it on[Solved]Will you be able to bring 6 people with you in case it rains. Paddy Power is giving 5 to 1 for rain........
One of the s2000 lads hads the same problem. you're right though it'll ease up after a while.. I'll be there on Sunday anyway
Re: Just fitted softtop, can't latch it on[Solved]On a car meet I hope more than 6 people will show up, indeed
x-'91 1.6
x-'94 1.8
