timing and cam belts
Re: timing and cam beltsthey're the same belt
Where are you based?
Re: timing and cam beltsI'd say 200 euro but you could do yourself for maybe 80 euro including buying crack locking tool etc.
Re: timing and cam beltsThe parts required are 120e ie waterpump,2 pulleys,t.belt and coolant.!!!
Re: timing and cam beltsCheers robert, of course Water pump replacement not mandatory but recommended....
Re: timing and cam beltsRob is correct ,you might consider cam and crank shaft front oil seals as well ,there not expensive and worth doing when you/mechanic is that far .
Cam box cover gasket and cas seal also easy to do at this stage ,you've done/paid for the labour anyway Best of luck Brian ]96 na Merlot edition. sold
Re: timing and cam beltsThanks for the replies ....the 250 price looks ok ...anyone in Galway do it for that...
Re: timing and cam beltsBrendan Dowling in Shantalla is a bit of a living legend. He owns an MX5 too : http://www.mechanicingalway.com/
Alternatively, give Greg in Complex motors in Ballybrit/Ballybane a ring for quote : 091 759446 or 087 0918020. I've had some work done by him in the past and hes good.
