timing and cam belts
Tue, 19 Mar 2013 11:47 +0000
by michaeltburke
Does anyone know what supply and fit of timing and cam belts would cost at a non dealer garage ?
Re: timing and cam belts
Wed, 20 Mar 2013 2:54 +0000
by rhysmate
they're the same belt
Where are you based?
Wed, 20 Mar 2013 7:56 +0000
by pjmazda
I'd say 200 euro but you could do yourself for maybe 80 euro including buying crack locking tool etc.
Wed, 20 Mar 2013 8:00 +0000
by MX5Spares
The parts required are 120e ie waterpump,2 pulleys,t.belt and coolant.!!!
Wed, 20 Mar 2013 8:03 +0000
by pjmazda
Cheers robert, of course Water pump replacement not mandatory but recommended....
Thu, 21 Mar 2013 12:50 +0000
by Merlot man
Rob is correct ,you might consider cam and crank shaft front oil seals as well ,there not expensive and worth doing when you/mechanic is that far .
Cam box cover gasket and cas seal also easy to do at this stage ,you've done/paid for the labour anyway
Best of luck
Brian
Fri, 22 Mar 2013 12:55 +0000
by michaeltburke
Thanks for the replies ....the 250 price looks ok ...anyone in Galway do it for that...
Fri, 22 Mar 2013 4:59 +0000
Brendan Dowling in Shantalla is a bit of a living legend. He owns an MX5 too :
http://www.mechanicingalway.com/Alternatively, give Greg in Complex motors in Ballybrit/Ballybane a ring for quote : 091 759446 or 087 0918020. I've had some work done by him in the past and hes good.
