Purchased one of these chips on Ebay ( I know it's more than likely crap)
But it's only two wire installation and can be removed easily, then your back to standard.
So I would like to give it a try anyway?
Problem is it connects to two cables of the Air Intake Temperature Sensor, which I believe is housed within the Air Flow Meter, but I have five cables coming from the terminal connection unit on the Air Flow Meter.(Guessed the question)?
My car is 1996, 1800cc.
Cables as follows from terminal connection.
(1) Large white and red cable
(2) Small red and white cable
(3) Small red and black cable
(4) Small black cable
(5) Small black and green cable
The chip has two cables, one connects to the Air Temperature Sensor signal cable and the other to the sensor power cable.
(Sounds easy don't it)
Anyone know which of the cables above are the one's to connect to ?
Help!
