Welding Frame Rails Near Fuel Lines
Postby rhysmate » Wed, 04 Sep 2013 4:55 +0000
I failed nct on a small rust hole on the frame rail.
if i run the lines dry while the relay is out and disconnect the lines from the tank and the engine, will i be safe to weld near them ? i cant see why not but anybody else with experience on this might comment?
Re: Welding Frame Rails Near Fuel Lines
Postby sidewaysreilly » Wed, 04 Sep 2013 9:44 +0000
How near
Postby MX5Spares » Wed, 04 Sep 2013 9:46 +0000
Still vapour in the lines.Why not remove the bolts holding the pipe brackets and push away a few inches !! Is it gas or mig welder ??
Postby rhysmate » Wed, 04 Sep 2013 10:38 +0000
its within 4-5 inches anyway. is it easy to drop the lines? its a gas mig welder
Postby sidewaysreilly » Wed, 04 Sep 2013 10:51 +0000
Wouldn't bother me to much but neither does mig welding. Drain the lines, and get them well clear. To be save have extinguishers at hand. Don't do it alone and plan escape route.
Postby rhysmate » Wed, 04 Sep 2013 10:57 +0000
Cheers man, i will haha! id say once the lines are clear and have been left for a while to air out it should be ok. ill put a fire blanket around them, just in case!
