change the hose between oil cooler and thermostat.
Postby emarkey » Fri, 18 Dec 2015 7:22 +0000
Anyone have any tips on the title? I need to change it and its in a bastard of a spot.
emarkey
Re: change the hose between oil cooler and thermostat.
Postby sidewaysreilly » Sun, 20 Dec 2015 8:24 +0000
If you take off the inlet manifold support bracket it will give you room. 3 Bolts, on mk2 engine anyway.
Postby scallan » Sun, 20 Dec 2015 11:39 +0000
I got rid of that bracket altogether as it makes changing the oil filter handier aswel
scallan
Postby emarkey » Mon, 21 Dec 2015 7:23 +0000
Fairly sure I lost that bracket anyway. Still a bitch of a spot
emarkey
Users browsing this forum: No registered users and 23 guests
