Aircon.....
Aircon.....
Postby mrges » Sun, 05 Jun 2016 11:22 +0000
Hi - actually posted this in a reply to another thread - then thought it would probably be better suited here:
The aircon isn't working...... I'm guessing it's a "re-gas" job (well, I'm hoping it's only a "re-gas" job!). Has anyone had this done? If so, can you recall where (and approx. cost)?
Any other possible reasons it may not be working (anything in particular I should look for)?
Thanks.
G
Re: Aircon.....
Postby Merlot man » Mon, 06 Jun 2016 8:34 +0000
Not on the mx5 but done it a few times on the daily , basically takes about an hour and around 60 -80
They check for leaks by running a uv dye through the system and then fill with refrigerant gas and lubricant oil .
I'm sure there are a number or garages in your area doing this and if they don't they will know how does .
Hope this helps
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
Re: Aircon.....
Postby mrges » Tue, 07 Jun 2016 12:30 +0000
Hi Brian - thanks for the info. eunos-r also got back with some possible places in Mullingar who might do this. Will give them a shout and take it from there. Having said that, if it's not raining, and not freezing cold, dropping the roof does a pretty good job of keeping things cool!
Graham
Re: Aircon.....
Postby PearseMc » Tue, 14 Jun 2016 9:15 +0000
Hi Folks
Brought my newly acquired Eunos 1993 Mk1 to FirstStop on Malahide Road today to "innocently" ask them to re-gas my air con for their normal €60 (got my 08 c5 and mates 06 MB E200 done last year). They advised that the fittings on their equipment would not fit my Eunos Air Con system and that my car uses a different type of gas to the one they use nowadays...
I would be grateful if for any information on where I could go to get system re-gassed and some idea of the cost.
Pearse Mc
PearseMc
Re: Aircon.....
Postby MX5Spares » Wed, 15 Jun 2016 4:07 +0000
There is indeed two types on AC gas.Old systems use different to modern cars (RF12A? if I remember correctly)There is usually a sticker on front panel near the rad showing gas type.Later ones are RF134 maybe.It is still possible to get someone to re gas the older cars.
Re: Aircon.....
Postby andrew » Thu, 16 Jun 2016 5:14 +0000
Yes, 93's used the older gas. You will need a drop in replacement gas, not R134a that is used in modern cars. You need to call a auto a/c specialist. I doubt any of the tyre garages could do this.
andrew
Re: Aircon.....
Postby sidewaysreilly » Sun, 19 Jun 2016 5:37 +0000
Halfords sell a re-gassing kit. Worked grand on 2 cars for me albeit Hondas.
Re: Aircon.....
Postby AndyJF » Mon, 20 Jun 2016 12:04 +0000
I've used the Halfords one before. Works perfectly.
Unfortunately the last time I re-gased the MX5 it blew a seal. (It was badly perished)
Sent from my A0001 using Tapatalk
AndyJF
Re: Aircon.....
Postby MX5Spares » Mon, 20 Jun 2016 5:09 +0000
You cant use the newer gas in older systems and vice versa.
Re: Aircon.....
Postby AndyJF » Tue, 21 Jun 2016 9:29 +0000
But you can get them converted. Probably easier to get a second hand newer one into it though
Sent from my ONE A2003 using Tapatalk
AndyJF
