Drains
Drains
Postby micko » Sat, 28 Jun 2008 5:25 +0000
just doing some "housework" on the car while it ain't raining and i've found a silly amount of gunk in the roof drains so that's one problem solved...
next up are the sill drains underneath the car. there should be two somewhere near each jacking point but to be honest i've had the head under there and i've poked about a bit and i can't see anything resembling a drain hole :oops:
can anyone post a picture showing the exact location of these holes clearly? all i can find on the 'net are very vague pictures showing the jacking point and the diagram from the mazda service bulletin.
many thanks
Mick!
micko
Postby mx5ash » Sat, 28 Jun 2008 6:20 +0000
Get a long bit of wire and stick all the way down from above then you'll see it come out the bottom or the rear drain holes. The front ones are in line with those but further....well forward.
hth ash
Postby Steve » Sun, 29 Jun 2008 6:58 +0000
yeah, they kinda look like a split in the sill near the jacking point..
