Gear box oil
Gear box oil
Postby mrges » Sun, 01 Sep 2019 9:45 +0000
Changed the gearbox oil earlier, and also set about replacing the rubber bits on the gear lever. There was some (as in a little) dirty oil in the turret ...
Does anyone know how much should be in there? Do I fill the turret (this bowl) completely? It only had oil in the bottom when I drained it.
Many thanks.
Re: Gear box oil
Postby mrges » Sun, 01 Sep 2019 9:49 +0000
Oh, and I used a good hack found on the internet - filling the gearbox would be a bugger of a job without a hoist/ramp or some kinda special pump.... but a bit of hose attached to a funnel at one end, and the other end slotted into the gearbox, worked well.
Re: Gear box oil
Postby Pops » Mon, 02 Sep 2019 1:40 +0000
Great work done there, the turret only takes a small amount of oil, probably as much as you got out plus a drop, when you refit the gear leaver it will force out whatever it’s over filled by
Re: Gear box oil
Postby mrges » Mon, 02 Sep 2019 1:16 +0000
Great - thanks for that. Turret filled and everything (hopefully everything!) refitted correctly and tightened up. Just need to get it off the stands and back on the ground again, then go for a drive to see if it made any noticeable difference.... but it's lashing here at the moment, so the drive will have to wait a while longer.
Re: Gear box oil
Postby 93 Mk1 » Tue, 03 Sep 2019 8:47 +0000
I just filled mine up enough so that it wouldn't spill over when everything was reassembled.
