Adjustable headlight alignment - should I tell Nct tester?
Postby SilverDoll » Tue, 19 Nov 2019 11:08 +0000
My Mk2.5 failed the NCT because the headlights were misaligned. Is it possible that the headlights were only misaligned because they tested the car with no driver? Should I have told them about the knob on the dash that changes the alignment to account for the weight distribution in the car? There are four settings: driver only; driver and passenger; driver, passenger and weight in boot; driver and weight in boot but no passenger.
SilverDoll
Re: Adjustable headlight alignment - should I tell Nct teste
Postby Steve » Tue, 26 Nov 2019 11:17 +0000
interesting, I didn't know that was a thing in the mk2.5, absolutely tell them if that is the case.
Postby johnv » Wed, 27 Nov 2019 9:39 +0000
There is an adjuster. But i don't think it effects alignment
johnv
