Lower stereo unit removal?
In car entertainment
Postby satfan54 » Fri, 28 Aug 2009 6:17 +0000
Hi to all.
could someone please tell me how to remove the plastic box under the stereo. I have the stereo removed and can feel around the lower box but cannot detect whatever is holding it in position.
Thanks.
satfan54
Re: Lower stereo unit removal?
Postby leamyj » Sun, 30 Aug 2009 2:52 +0000
In a mk1, you have to dismantle the console and pop the eyeball vents, it's only screws and a little knack on the vents...assuming yours is a mk1. Dunno about mk2's :|
Postby satfan54 » Sun, 30 Aug 2009 10:24 +0000
Thanks for that John.Its a Mk1 ok.
Peter.
satfan54
Postby Stig » Thu, 01 Oct 2009 6:50 +0000
leamyj wrote:In a mk1, you have to dismantle the console and pop the eyeball vents, it's only screws and a little knack on the vents...assuming yours is a mk1. Dunno about mk2's :|
Not necessarily, I've been into my centre radio console many times, without ever having to pop the vents. The cubby box is screwed into place with 2 done headed Philips head copper coloured screwed (from memory), and can be accessed (albeit ackwardly) when you pull the centre conole out from the bottom.
Return to I.C.E
