Sub
In car entertainment
Sub
Postby mx5isola » Fri, 22 Feb 2008 10:38 +0000
Hello...
I have a 12" sub in my fiesta that i wanna keep...will it fit in the boot? Also, how easy is it to put my component speakers in not sure where id put the tweeters!
Nicole
Bye Bye Fiesta....Helloooo MX5!!
mx5isola
sub
Postby mx5ideways » Fri, 29 Feb 2008 2:40 +0000
you could keep your sub no problem,just get a good carpenter to make you a sub box that wil fit your boot,you could even fit it behind the seats too on the shelf as long as its an (open air sub)-works better if theres alot of air around it,you could fit your tweeters anywhere around the front of the car or the doors.
mx5ideways
Postby sandyland » Fri, 29 Feb 2008 2:11 +0000
This is the set up that I did have in my mk 1 for a while. It was a 10inch JL and to be honest a real good set of 3way front speakers like the ones from FOCAL and some Dynamat in the doors do produce a better sound and nearly the same bass as adding a sub.
With the sub I noticed that over 90km/hr it was not very effective but when stopped in traffic it really could be heard!
I took my sub out as I found the car not to be as sharp thru the twisty stuff as it should be :wink:
This is what my boot did look like:
http://i275.photobucket.com/albums/jj28 ... C01431.jpg
If its not broken, I havent fixed it!!
sandyland
Return to I.C.E
