I have a set of koni lowering springs for a mk1 35mm drop never used only 1 spring was test fitted
€55
Koni lowering springs for mk1 €55I have a set of koni lowering springs for a mk1 35mm drop never used only 1 spring was test fitted
€55 You do not have the required permissions to view the files attached to this post.
Re: Koni lowering springs for mk1 €55What koni shocks are they recommended for and are they strictly for use with an mk1?
Re: Koni lowering springs for mk1 €55Not too sure about which koni shocks they can be used with I was gonna use them on my original shocks but I'm going with coilovers instead
Re: Koni lowering springs for mk1 €55If they work with my koni yellow sports I'll take them off ya. Can you give me the part number off the box and I'll look into it. Whee are you based.
Re: Koni lowering springs for mk1 €55Sold sold sold
