Mk1 1.8 Cylinder Head & ECU for sale
Postby philr » Wed, 21 Sep 2011 11:02 +0000
Hi folks
I've a mk1 1.8 cylinder head off a low mileage (~70k mls) 1997 car for sale.
Included in the sale is:
Cams, cam pulleys, Cam position sensor, Cam cover
Inlet, throttle body, TPS, ducting, airbox
Exhaust headers - think 1 or 2 studs might need replacing but nothing major
Injectors, fuel rail
Have a couple of seals and gaskets that I can throw in if needed. No head gasket though...
I have photos that I can email if needed.
€190 ono
ECU from the same motor - €50
Also an alternator of unknown functionality but looks pretty clean! - €50
Flywheel/Pressure Plate - €50
Based near Galway city.
philr
Re: Mk1 1.8 Cylinder Head & ECU for sale
Postby charged_rs » Wed, 21 Sep 2011 9:17 +0000
phil , can you weigh the flywheel ?
Postby philr » Thu, 22 Sep 2011 10:00 +0000
Hey
I'll drag it into the job tomorrow and put it on the scales.
It has had no machine work on it.
Phil
philr
Postby philr » Mon, 26 Sep 2011 9:25 +0000
The flywheel is coming in at 7.9kg
Phil
philr
Postby sidewaysreilly » Wed, 28 Sep 2011 12:32 +0000
what weight are the light ones Paul????????
Postby philr » Wed, 28 Sep 2011 5:41 +0000
Flyin' miata do a 4.6kg and a 6.1kg...
Light one for n/a and turbo motors and heavier one for supercharged
That's some difference compared to the stock flywheel either way!
philr
Postby philr » Tue, 25 Oct 2011 2:00 +0000
Finally got a few pics together -
Open to offers...
Phil
philr
Re: Free Mk1 1.8 Cylinder Head
Postby philr » Mon, 25 Nov 2013 12:41 +0000
Free to a good home!
The cylinder head / cams / camcover and inlet/exhaust manifold is still available
philr
