This Greddy kit will be 'Plug & Play' for any 1.6 up to 5/6PSI
It is a mix of the 'basic' 1.6 Greddy Turbo kit and it will also have parts from my own previous build/setup which I ran with no problems at all for years. The only things you will need are the oil feed/return lines and nothing else.
You will end up with this...except you'll still have your AFM and a different air filter there going into the Turbo.
For this (100% perfect) Turbo and all of my own upgrades added in (which cost me over 250 euro) I am looking for 900 euros complete.
This kit with my setup is plug & play power - bolt it on, set your timing to 6 degrees and nothing else but GO BOOST !
