All located in Lucan, Co. Dublin.
Dash (black): €30
Wings : €70 - passenger side has one small ding and a couple of scratches; driver's side is perfect. Both in red.
Front bumper €30 (red, faded, would need painted)
Front number plate plinth €20
Hardtop mounting plates and Frankenstein bolts €30
Rear bumper : €10 (red, faded, would need painted - has two cutouts for dual-exhaust)
Bonnet: €30 (red, faded)
Door card: €30 each (black and with aftermarket pockets)
leatherette pocket for zip-down window €20 (sits on rear deck and receives plastic window like an envelope, protects it when zipped down)
small leatherette storage pocket €20 (sits behind the seats, attached to the vertical carpet)
ashtray (never used) €10
rear light unit €20 each
front light unit (takes H4 bulb) €20 each
front light metalwork and plastic bowl €20 each
UK rear number plate panel €60 (red)
radio panel €20
eyeball vents €5 each
headlamp motors €15 each
pair of crystal front indicator units €50 http://www.mx5parts.co.uk/front-indicat ... p-942.html
standard 1.8 underbody chassis frames €20
differential, 1.8 1996 model open diff and carrier €140
engine, 140,000 miles on it (70K of it was turbo'd). In good condition but head is separated from block (to assist turbo removal) so would need head gasket and timing belt. Water pump has 400 miles on it. €120
driver's door with mirror and glass, €40 (perfect condition, red)
passenger door with mirror and glass, €20 (paint is faded badly, window glass is scratched badly)
door locks and latches €40 for the set
1.8 1996 ECU (OBD2 version), €60
1.8 air-flow-meter AFM €40
Momo champion steering wheel and boss €100
standard 1.8 air intake €10
seats €40 (black, separate headrests - passenger seat is perfect, driver's seat has worn bolster)
dash clocks and binnacle €30 (Perfect condition, UK spec 1.8, in mph and kph, showing 140,000 miles)
leather gearstick gaiter €15 (perfect condition, black)
boot lid, €10 (red, faded, slight dent)
spacesaver spare wheel €10
Black OEM tonneau cover (for the rear deck) €25
Brand new unused trackrod end €15 (http://www.mx5parts.co.uk/track-afterma ... p-555.html)
New and unused clutch slave cylinder (I have two of these): €15 each http://www.mx5parts.co.uk/clutch-slave- ... p-252.html
Thermostat €5 (no gasket) http://www.mx5parts.co.uk/thermostat-af ... p-247.html
Rear lamp gaskets, genuine Mazda, unused and still in packets €10 each http://www.mx5parts.co.uk/rear-lamp-gas ... -1415.html
