mk1 Mazda OEM chassis braces eur20
Postby franksm » Sun, 20 Sep 2015 10:42 +0000
Mazda OEM chassis braces for the mk1.
These were fitted to the 1.8 model and help increase the rigidity of the car. These are very easily retrofitted to earlier cars, the bolt holes are already in the chassis.
Located in Lucan/Belfast, in good condition. eur20
They have been off my car for a long, long time but if I remember correctly, the long U-shaped bar on the right goes under the engine and gearbox.
The smaller bar fits under the rear diff.
Re: mk1 Mazda OEM chassis braces eur20
Postby Merlot man » Sun, 20 Sep 2015 8:27 +0000
Hello frank,
Can you or anyone on here confirm if these will fit under a 93 jap Import car , I can't see the holes to fit them to the body, the rear sub frame is ok as its from a later car , either way I'll have the alignment and shock bolts from you . Would you be ok with posting the bolts if the chassis braces don't work out ?
Can you pm me your PayPal details,
thanks
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
