The time has come to clear out the shed so here's the first of a few bits for sale....
There's plenty of info about fitting a mini supercharger to an mx5 and whilst not a complete kit this will bring you pretty close to going FI .
Remaining few parts (inlet/outlet/pipes etc) can be got from Trlane. I'll help the buyer with what ever advice I can give.
What's for sale is everything in picture below which is....
Supercharger From a low mileage mini and has the Teflon coated rotors. I had it fitted with a 54mm pulley (17% reduction) so will deliver decent boost.
It has a blanking plate fitted that is needed as part of the conversion and also comes with a mounting bracket. Bracket may need a little finishing to get fit 100% right.
2nd throttle body with blanking plate and spacer
Tensioner plate and pulleys
Mini filter
3 X gates belts 4pk1368 (2 spares)
Set of 1.8 injectors. Useful if installing on a 1.6
Thermal intake gasket
Innovate Wide band o2 and gauge
Whole lot for €900
