COIL PACK
COIL PACK
Postby Lynott » Wed, 23 Jul 2008 9:25 +0000
I have a coilpack for a 1.6ltr Mk1. I bought it and then discovered the plug lead was the problem and not the coilpack. I'm learning ! ! From MX5-Parts £143 sterling plus P+P. Bargain at 60euros
http://www.mx5parts.co.uk/advanced_sear ... =coil+pack
(Had a) White 1991 MX5 1.6, (Had a) Cream Toyota Cressida DX, Have a Silver Mercedes CLK, Blue Yamaha Grizzly, Purple Renault 16TX
Lynott
Postby sspecdave » Wed, 23 Jul 2008 9:53 +0000
YOU HAVE PM :!:
Postby Steve » Thu, 24 Jul 2008 2:47 +0000
If you haven't sold it already, give me a shout.. mine is sparking a bit ;-)
Postby Decay » Tue, 14 Oct 2008 10:25 +0000
And if you still haven't sold it.... mine is sparking a bit more than a bit....
Dave
Decay
Postby Steve » Tue, 14 Oct 2008 11:59 +0000
Dave,
I bought Lynott's new coil pack, but he does have a used one for sale too (its sitting in my hallway at the moment, it tested out prefectly BTW).
Postby Decay » Tue, 14 Oct 2008 1:23 +0000
Cheers Steve, what kinda price do you know?
Dave
ps any other craic with you?
Decay
Postby Steve » Tue, 14 Oct 2008 1:55 +0000
Don't know what he is looking for it, am sure he'll be on to you soon.
Nope, no craic, have you decided what you are doing with the turbo? ;-)
Postby Decay » Tue, 14 Oct 2008 2:02 +0000
Cool, we should be able to sort something. Replaced plugs and leads which fixed most of the problem but noticed a small hole in the pack's insulation which is causing the odd misfire.
As for the turbo, no, no-one bought it, car has been displaying a tendency to overheat on long runs which had me concerned, after much fiddling I reckon it's the radiator itself that's knackered, need to replace that and see if it's sorted and then, who knows.....
Decay
Postby Steve » Tue, 14 Oct 2008 3:25 +0000
Try looking at the coil at night with the car running, you should be able to see where its sparking.
if you are replacing the rad.. maybe look into putting in a civic one instead, its narrower, which will come in handy when you want to run intercooler pipes ;-)
Postby Decay » Tue, 14 Oct 2008 6:29 +0000
I can see where it's sparking, it's not too bad at the moment but it's only going to get worse.
And stop with the dark side technical advice :wink:
Decay
Postby Steve » Wed, 15 Oct 2008 11:27 +0000
You know you want to.. ;-)
Postby Lynott » Fri, 17 Oct 2008 12:41 +0000
Decay I pm'd you
Lynott
Postby Lynott » Thu, 30 Oct 2008 7:49 +0000
Decay I just pm'd you again. Sorry for the delay in getting back to you
Lynott
Postby Lynott » Sat, 06 Dec 2008 2:45 +0000
The coilpack is sold. Thanks
Lynott
Postby K10 » Tue, 27 Jan 2009 7:11 +0000
srigley wrote:Dave,
Are both of them sold?
http://www.corkmongolia.com
K10
