I need a Timing/Accessory pulley for a 1.6 shortnose crank (has 4 slots on the front) came on cars 89-91 i think.
thanks
timing pulleyI need a Timing/Accessory pulley for a 1.6 shortnose crank (has 4 slots on the front) came on cars 89-91 i think.
thanks ger
![]() tried www.boundville.co.uk ?
Is this to solve your earlier problem? Did you do the "find TDC with screwdriver" test? Steve
![]() got the bits for autolink, going to replace the whole lot back to the crank, plus crank oil seal.
![]() cool! Could you take pics if you have time? I'll be doing the same seal this summer (along with waterpump, timing belt, etc)
![]() Ta! Steve
