bolts for underbody
bolts for underbody
Postby mx5ideways » Mon, 06 Apr 2009 11:27 +0000
i need the 2 bolts holding on the forward part of the diff(also hold up the power plant frame)the threads are crossed on one of mine and the other one keeps loosening cause of the vibrations,anyone know where i could get them no?
mx5ideways
Re: bolts for underbody
Postby Steve » Tue, 07 Apr 2009 1:00 +0000
You could try bringing them to the local hardware and matching them up (especially the rear most one) or give www.boundville.co.uk a ring..
Postby mx5ideways » Tue, 07 Apr 2009 1:24 +0000
srigley wrote:You could try bringing them to the local hardware and matching them up (especially the rear most one) or give http://www.boundville.co.uk a ring..
cool thanks il order them from boundville,its working out at around 25 inc postage and all
mx5ideways
Postby MeathMazdaMan » Tue, 07 Apr 2009 9:01 +0000
got heaps bolts, perhaps you could post size and length, I completely dismantled 1.8 over the winter so i have them alright, dont label bolts though, doorcards also in stock, P
MeathMazdaMan
