Hi looking for a the black cowl that sits behind the steering wheel.
Snapped two of the holders today when I was checking cables behind it.
Instrument binicle/podHi looking for a the black cowl that sits behind the steering wheel.
Snapped two of the holders today when I was checking cables behind it. You do not have the required permissions to view the files attached to this post.
![]() Re: Instrument binicle/pod2 of the clips that go into the dash mate?
I did that (as have most people how have ever taken them of) no major worry though i never fixed or replaced mine stays in just fine and doesn't rattle. ![]() http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
![]() Re: Instrument binicle/podUsed two sided tape today
![]() Fecking indicator won't indicate right! Stalk goes down but nothing happens. Left and full heads working fine.
![]() Re: Instrument binicle/poddo all the lights work ok with the hazard button PJ? Bit of a coincidence that you had the cluster our last Fri..
![]() Re: Instrument binicle/podALL other things working, it's the side that has the little led light on it, I remember fustering a good bit tryin to put back the led, so I must have done something when I was at it
![]() In to the garage in the morning with it, so I'll be road legal for Roscommon!
![]() Re: Instrument binicle/podif you can hang on till lunchtime I'll pop over and have a look
