Rear brake caliper R/HLooking for a '92 MX5 rear brake caliper R/H.
Re: Rear brake caliper R/H
Hi Laur, You'll need to specify 1.6 or 1.8. ![]()
![]() Re: Rear brake caliper R/HIts a 92.. so its a 1.6.. all pre '03(at least) calipers are the same anywhoo.. its the brackets that are different. </nerd>
laur, if you can wait till next week I'll have one available (if I can get dry day to remove it).
![]() Re: Rear brake caliper R/HThat's will be fine. Yesterday i have changed the break pads but the piston get rust and it's in a bad shape and the brake fluid it's leaking
