Frankenstein bolts
Frankenstein bolts
Postby Medic5 » Mon, 25 Oct 2010 9:19 +0000
Thinking it's time to put the roof back on.
I'm looking for two frankenstein bolts.
Re: Frankenstein bolts
Postby sidewaysreilly » Tue, 26 Oct 2010 12:41 +0000
so am i lad.......
Postby johnv » Wed, 27 Oct 2010 9:29 +0000
i got a pair of bolts from mx5 parts to day . when i went to fit them. there is no recievers. i thougth there would be captive nuts or something. i cant see any way of reaching the bolts to put a nut on any one any ideas need to get this sorted as im picking up a hard top this weekend i hope. john
johnv
Postby Medic5 » Thu, 28 Oct 2010 10:12 +0000
Hi John, you should be ok without the bolts.
I've a hard top on my car for past 3 years, without bolts.
The four clips hold the top in place with no difficulty.
Postby Steve » Thu, 28 Oct 2010 12:42 +0000
Is there two large philips head screws there at the moment John?
You'll need to replace the inner one with the new frankenstein bolt
Like this :
Postby johnv » Thu, 28 Oct 2010 8:25 +0000
there are philips head bolts in the rear holes but nothing in the front i put rubber grommets in to stop leaking
johnv
Postby Steve » Fri, 29 Oct 2010 12:13 +0000
ah I see, hmm, I had helicoil inserts put into a cylinder head last year by an engineering shop for small $$.
These guys might know someone local to you that could do similar :
http://www.jgengineering.ie/contact_1.html
