Cat for a mk2/2.5
Cat for a mk2/2.5
Postby sidewaysreilly » Sat, 13 Nov 2010 5:32 +0000
Need a Cat for a mk2/2.5 to join to a Japspeed 4 branch manifold. Dont wanna cut the end flange off. This is the standard cat with short length of pipe on the end.
Re: Cat for a mk2/2.5
Postby sidewaysreilly » Fri, 26 Nov 2010 8:03 +0000
humpty bumpty
Postby leamyj » Sat, 27 Nov 2010 11:15 +0000
Sat on a wall??? :mrgreen:
Postby andrewmag122 » Tue, 30 Nov 2010 1:19 +0000
would a mk1 cat do
andrewmag122
Postby sidewaysreilly » Wed, 01 Dec 2010 12:46 +0000
no, have one on it, well put it back on for nct but the manifold i have is 2 1/4 inch bore to fit a mk2 . Can cut the de-cat i have to fit but dont want the hassle of swapping every 2 years so the 99ish mk2 is what im after.....i think!
Cheers anyways.
Postby sidewaysreilly » Mon, 10 Jan 2011 11:44 +0000
bump.......
Postby TeenaG » Tue, 11 Jan 2011 12:38 +0000
TeenaG
Postby sidewaysreilly » Tue, 11 Jan 2011 1:45 +0000
Teena your a looooooooon :D :D :D :D
Postby steo84 » Tue, 11 Jan 2011 11:34 +0000
1.6 or 1.8?
steo84
Postby sidewaysreilly » Thu, 13 Jan 2011 11:22 +0000
1.8 98-01 model i think. Later ones had the cat on the down pipe. 1.6 may do. Its a 2 1/4 inch bore flange.
Postby steo84 » Sat, 22 Jan 2011 9:50 +0000
ive a cat from a 98 1.8 jap rs model if thats any use to you.
steo84
