Front hub nut 29mm socket
Postby austin99 » Tue, 22 Mar 2011 1:41 +0000
Hi there,
I'm new here... I have an MX5 with a front wheel bearing that is making some pretty ugly noises. I've sourced a replacement hub which includes the wheel bearing but the problem I have is that the hub nut requires a 29mm socket (I've no idea why Mazda opted for 29mm instead of a standard size like 30mm)...
So I was wondering if there was anyone in the Dublin area (I'm in Dublin 8) who'd have a 29mm socket 1/2" drive or 3/4" drive and bar that I could borrow? I'll happily leave a deposit behind as well. The job is a simple one which should take 30 mins I reckon so I'll have it returned in no time at all.
Many thanks,
Austin
austin99
Re: Front hub nut 29mm socket
Postby johnc55 » Tue, 22 Mar 2011 2:53 +0000
Hi austin.
just checked my socket set and it goes from 27 to 30. 29 seems an odd size. sorry can't help.
JohnC
johnc55
Postby mx5ash » Tue, 22 Mar 2011 4:48 +0000
29 is an odd size, Dave from here has one that fits as I used it on mine but hes down here in Waterford. Maybe a local motorfactors stock them or friendly garage might lend you one.
Postby austin99 » Tue, 22 Mar 2011 6:15 +0000
Thanks for the replies. I rang around a few places including a local kwikfit and nothing doing....so I thought I'd chance my arm and ring the breakers yard where I got the part to see if they'd lend it out. He used a 30mm 6-sided socket to get it out and it came out relatively easily. I might try that tonight and see what happens
austin99
Postby Steve » Tue, 22 Mar 2011 6:17 +0000
I've a 29mm here I've used on mine, can stick it in the post if you are stuck.
Postby austin99 » Wed, 23 Mar 2011 1:35 +0000
Steve wrote:I've a 29mm here I've used on mine, can stick it in the post if you are stuck.
Thanks for the offer - I'll try and improvise with the 30....although I have to go buy a 6 point 30mm as the one I have is a 12 point one and would in all likelihood round the nut. If it ain't working out, I'll drop you a PM. Thanks again
Austin
austin99
Postby zagadka » Sun, 24 Apr 2011 2:41 +0000
In case anyone finds this thread like I did whilst looking for the socket; I got one at McQuillan Tools on Capel Street in Dublin... m
zagadka
9 Euro BTW.. M
zagadka
