Anyone dealing with electronics suppliers regularly???
Postby sidewaysreilly » Thu, 08 Dec 2011 9:40 +0000
Need an 8.8 mhz crystal of the HC49 variety for my rev limit raising mod. Think they are used in lots of TV'S .
This one..... http://www.donberg.ie/catalogue/passive ... 38mhz.html
Problem is, you need to spend a minimum amount of money 20 or so and they only cost 40 or 50 cents each.
Re: Anyone dealing with electronics suppliers regularly???
Postby leamyj » Thu, 08 Dec 2011 10:49 +0000
i could pick this up in radionics if they have it in stock...
Postby sidewaysreilly » Thu, 08 Dec 2011 11:24 +0000
Thanks John but it has an 8 meg as standard so fuel cut at 6900. Need the 8.8 for 7590 rpm cut.
Postby shaneh » Fri, 09 Dec 2011 3:40 +0000
ive a spare ecu there and wouldn mind raising my rev limit haha
hows it done if you dont mind me asking?
shaneh
Postby leamyj » Fri, 09 Dec 2011 9:59 +0000
sidewaysreilly wrote:Thanks John but it has an 8 meg as standard so fuel cut at 6900. Need the 8.8 for 7590 rpm cut.
Just checked and they don't have a crystal at that frequency, closest is 9.83
Postby sidewaysreilly » Fri, 09 Dec 2011 11:13 +0000
Too high John, just want a 10% increase cause any more will lean the mixture too much.
Shane check out "overclocking ecu" on miata.net or google it. Wont do anything on a stardard engine except raise the rev limit but i need to stop the fuel cutting off at 6900 as its now able to produce power up to 7600.
1.6 are different crystal wise but apparently it works on them too.
Postby shaneh » Fri, 09 Dec 2011 3:11 +0000
thanks il take a look ...
if you get a port polish and a lot skimmed off the head as well as raise your
rev limit youl make good use of the extra revs.
might just do this.
port polish in the future too.
thanks
shaneh
Postby sidewaysreilly » Fri, 09 Dec 2011 6:14 +0000
Its a BP5A from a mk2 , wanted solid followers and its good to 7500 but have a few other goodies bolted on too so need the revs to benifit.
Postby barney » Mon, 12 Dec 2011 1:28 +0000
Shaun, i'm not far from Donberg. You could contact them to see if they would sell you one if it was collected. If so i could collect and send it to you. text me on 087 6715466
Postby sidewaysreilly » Mon, 12 Dec 2011 5:54 +0000
This is the one i need Barney. If you could get it that would be great lad.
http://www.donberg.co.uk/descript/8/8.867238mhz.htm
Postby barney » Mon, 12 Dec 2011 6:02 +0000
Shaun, collecting tomorrow morning. pm your address
Postby leamyj » Mon, 12 Dec 2011 7:42 +0000
Now, that's what this group is all about..Well done Brian :thumright: :rendeer:
Postby sidewaysreilly » Tue, 13 Dec 2011 12:20 +0000
Cheers Barney, standby......
Postby barney » Tue, 13 Dec 2011 4:14 +0000
in the post. keep the revs up.. :D
Postby sidewaysreilly » Tue, 13 Dec 2011 8:40 +0000
Oh they'll be at 7660 now after this mod..........Cheers Barney. I owe ya lad.
