reflectors
reflectors
Postby 531 » Thu, 30 Aug 2012 8:10 +0000
My mk1 Eunos failed NCT yesterday due parking brake imbalance, effort 15% (less than 16% is a fail) and handbrake lever travel. Should be easy for mechanic to fix, hopefully.
I also need to change the rear side reflectors from red to amber (despite the car having been through at least 2 previous NCTs with the red ones!).
Would anyone have amber rear side bumper reflectors for a Mk1/Eunos to sell or......?
531
Re: reflectors
Postby Steve » Thu, 30 Aug 2012 9:14 +0000
Hi,
Most just cover the reflectors in black insulation tape or remove them altogether for an hour or two ;-)
Calipers + handbrake cable just need to adjusted by the sounds of it, not a big job.
Re: reflectors
Postby 531 » Thu, 30 Aug 2012 10:01 +0000
Steve,
Thanks for the reply.
Would they pass it if they were now covered or removed, especially as it is highlighted on the report?
B
531
Re: reflectors
Postby MX5Spares » Thu, 30 Aug 2012 3:43 +0000
Covering them is fine as long as the reflector is not seen.but we have amber ones if you need them and possibly you need caliper as they give a lot of trouble ie seizing,etc.Robert Dublin 086 8226506
Re: reflectors
Postby 531 » Thu, 30 Aug 2012 4:37 +0000
Thanks Robert.
I think I am sorted for amber reflectors, I know some one who has some and might not need them for duration.....
Calipers shouldn't be stuck as I had reconditioned calipers fitted only about 6 months ago.
531
Re: reflectors
Postby MaXimu5 » Thu, 30 Aug 2012 5:04 +0000
I taped over my reflectors with duct tape and she passed no bother... got a bit worried when 3 testers took a close look when up on the ramp, but they were just admiring the stainless steel chassis rails I'd fitted... Phew..!. M.
MaXimu5
